Re: No Spark on any cylinder 87 F 125
Come on--Tell me why you replaced the stator. What was the problem?
No spark on all cylinders is usually to much of a coincidence so you need to check some common areas.
The two white wires coming from the CD boxes are the kill circuit. Both connect to the white terminal in the engine board. Disconnect them and see if you now get spark. If you do, the problem is in the white to blue circuit. At the switch, is white connected to one "M" terminal and blue connected to the other "M" terminal? At the engine terminal board is the blue wire jumped to ground? If not, you will not be able to stop the engine once you do get spark.
Be sure the electronic mounting plate is adequately grounded from the plate to the block. Factory used a black wire from the plate to the bypass cover bolt. If this wire is missing or broken, you will get no spark. I like to "daisy chain" a ground wire from each box and each coil to the ground terminal on the engine board.
