I am also having problems with a force engine hope someone can help. I have a 1988 85 hp force (thats probaly my first problem) I have spark on 2 and 3 but not on one. I've changed the coil packs around. I took the coil off of 2 which was working and put it for number 1 and 1 for 2 still no spark on 1 but spark on 2 so the coil pack is good. . I changed the cdi pack in the front which runs cyl 1 and 2 same thing spark on 2 but not on 1 even though they both run off the same pack (don't understand why that is unless one side goes bad) Thought maybe the stator changed that, same problem no spark on 1 but good spark on 2 and 3. now the odds of everything that I changed all being bad and causeing the same problem....not likely so....I was thinking maybe ground issue but then if that was the case i might not have any spark but I do. I also changed the trigger still no spark on 1. Now when i reverse the wires on the cdi pack they are org/red and switch them then I have spark on 1 but not on 2. I have also replaced all the wire ends with new ones thinking there was a broke wire same problem. Please help Thanks for any answers you can come up with. Signed FUSTRATED
