Re: not firing on one cylinder
ok, I took the carb apart once more. I put a single strand of wire through every oriface I could see. every jet was sufficiently clog free, I am quite sure. re-assembled everything.........................same problem. I even changed spark plugs just to be sure.
so now I have a question. I am assuming that my motor is not running correctly because when I pull the plug wire off the top left cylinder (when behind the boat), I hear no change in the motor. when I pull the plug wire off of any other plug, there is a noticable change, and it immediatly picks back up as soon as I even bring the plug wire close to the plug. this does not happen with the top left plug. I believe my assumption to be correct, that if I bother to bring my boat to the lake, I will have no power, and risk doing more damage to my boat as there will be no lubrication in the top left cylinder.
so...........to sum up my situation,
I believe spark to be fine, as there are one inch long lightning bolts going from the spark plug wire to my pliers when I pull the wire off, and spark is nice when tested on the plug.
I believe compression is fine. although it hasn't been tested in a few weeks, the motor hasn't been out of the driveway in that time, and there is no reason to expect different numbers (105 on the "bad" cylinder...between 103 and 110 on the rest)
I believe the carb is clean...........I've taken it apart twice now, every brass tube in there has had a wire strand passed through it, i've used compressed air at work, and i've personally used my lips to blow thorugh them.
I am running a carb cleaner in my gas tank, and I have used 2 cans of the aeorsol stuff.
Gas has to be my issue, but only on the top left cylinder. and I believe all jets are clear inside the carb.
I'm stumped now.
