No spark please help
littletex
I have a 1988 mercury 100hp motor with no spark . I've changed plugs , wires & coils , still no spark . There is no kill switch on my boat either . 1988 sea ray Seville . Getting fuel as well . Any ideas ?? Thank you so much for your time ..
Mortamie
Re: No spark please help
Does it have points? If it does you need to check your points and switch box... It might be one of those.. I am having same problem with my 1966 merc 950 .. My father in law who is a mechanic says that it is usually one of those.... Worth checking anyway
TD_Maker
No spark at all? I would seriously look at your key switch circuit. If the key switch is shorting out to ground, you have found the problem.
1nebel0
Mercury's love to eat switch boxes........There are no points in this motor.........real simple....go to the switch box and take off the yellow with blk stripe wire...if it starts, it is the kill circuit...
TD_Maker
Good job 1nebe10 I no longer have my shop manual to find the wiring diagrams. I am still leaning towards key switch .
