1972 evinrude 125hp,<br /><br />I have no spark on any cylinders. I dont know if its the coil the pulse pack or something under the fly wheel ( points etc ) I did a search on forum to see if i could find pinouts for the pulse pack or see if there was a way i could test voltages and ohms, It did this to me before, but after about a half hour of messing with it ( ie removing coil and cleaning up ground screws and putting it back ) it started up but i have a feeling what i did had nothing to do with it starting , that morning it was rainy and the afternoon was hot, today was the same thing , rainy yesterday and hot and sunny today, I have a manual i looked through it real quick to see if it has any tests for the aqua power corporation pulse pack part no 1640<br /><br />Can someone tell me what i should try testing first? how can i check the coil also if im going to need a pulse pack does anyone have one for sale.<br /><br /><edited in after posting><br />ok the search finally worked i found some info i guess i cant test the power pack however i forgot to mention that when the powerpack is connected and the key is in the on position i hear a very faint ticking coming from the engine ( possibly around stator area) when i dissconnect the power pack it goes away) So im going to try to test to see if the overheat sensor went bad hopefully my manual tells me how its a seloc manual (sigh)<br /><br />Thanks <br /><br />Paul
