WaterKrafter
- Joined
- Jun 12, 2017
- 19
I am on the edge...two weeks ago came across new-to-me cater fuel pump and Merc 2bl carb to replace old pump and Rochester 2bl carb. I installed and tested at ramp...adjusted linkage, she fired and idled at 650 rpm's without a hickup. Ok. Didnt want to leave ramp without a first mate to help row back should anything go south. Ok. Put her away until day and a half later to go out for test run. No Start!?! I piddled around scrathing my head...humm...ok. Well, I better check for bad fuel. Bad fuel and siphoned out the tank and put in fresh gas, new water sep. filter, pump fiter, inline inlet fiter...no start. Checked pump...pumping. In the meantime I put on new cap & rotor, new plugs, checked and adjusted timing to specs, checked for spark, pulled, disassembled, cleaned and reassembled carb and remounted.
Tried to fire her up after and found flooding again and again...
Any body have any directions for me? I have been on this thing for months. Plug wires are on firing order as spec 1342. I don't know where to go next!?! BooHoo Me!!!
