No Start and No Spark 1994 15hp Johnson Outboard
lmjpsl
I had the motor idling in the water for about five minutes. Then it just stopped and I couldn't get it to start again.
I checked that I had fuel flow at the fuel pump and fuel makes it to the carburetor. I bought a spark tester and hooked it up and while pulling the rope, the light does not light up on the tester. I would say that this means that I do not have spark for both spark plugs.
I read that I should try the kill switch, which I thought could be the culprit. I see that there are two wires from the kill switch: one goes to the ground on one of the screws on the ignition coil and the other goes to the connector for the power pack. I read there should be a yellow/black wire, but I do not see it. I just see these two wires and both are black.
My first question is if I disconnect the wire that serves as a ground, am I actually disabling the kill switch?
Secondly, both the ignition coil and power pack appear to be closed. they don't appear to open up for testing. How can I test why I am not getting spark with these two items?
Remove the one black wire that is the ground.-------That will bypass the kill switch.
lmjpsl
I removed it and there still is not spark showing on the spark tester when I pull the rope. Thank you for your response.
kbait
Search out the CDI troubleshooting guide. You can use a multimeter to check charge and sensor coil resistance. Coils are under flywheel, and you test from connector between flywheel and cd box. If they test good, you likely have a bad cd box..unless both drive coils failed at the exact same time (unlikely). Here's a new replacement cd from iboats: http://www.iboats.com/mall/partfind...gd_poid=112902&gd_row=38&session_id=110882558
Good luck!
