achris
More fish than mountain goat
- Joined
- May 19, 2004
- 27,468
...The coil + side to ground on the motor was 12 volts. When I put the negative lead on the coil negative and positive lead to the coil positive, I had nothing. Key was turned to on.....
That would be correct. The negative side of the coil doesn't go to ground. It's just the side the ignition module switches (to generate the sparks). Have a read of this....
http://forums.iboats.com/forum/engi...-mercruiser-thunderbolt-ignition-systems-work
You should find something in there that will point you in the right direction...
Chris........
