JENNIE116LOWE
- Joined
- Mar 31, 2013
- 86
Tried to start my 56 Evinrude 30 last night and today with no luck. I got this motor for a restoration project and before I tried to fire it up I did the following:Checked compression 110-110 Replaced coils, points, condenser, spark plug wires and plugs. Rebuilt carb, replaced fuel lines, rebuilt pressurized fuel tank. Replaced impeller and added fresh gear oil. I noticed today that there was no fuel in the fuel filter bowl and found that there was a clog on the fuel side of the male fitting on the engine. I fixed this and tried again with no luck. It turns over with no indication its trying to start. I did notice what appeared to be a backfire in the tank of water several times and a little oil gas mix in the tank. Not sure where to go from here. Its getting good spark and appears to be getting fuel. Any help will be appreciated.
