no start
chevyrocker
i need help again. i just replaced the impeller on my 1970 Johnson 9.5. Now it won't start. timing maybey?
iwombat
Re: no start
What all did you do (what got removed and put back), and what are the symptoms (no spark, coughs, etc.)?
iwombat
Re: no start
If all you did was remove the lower unit and put it back on, it could be that it's stuck in forward gear. How hard is it to pull? If it pulls hard, crack the lu again and double check that the shift linkage is in correctly.
chevyrocker
Re: no start
thanks but i got it started shortly after i posted. do you know which spark plug wire set i need?
thank you
