ahhhhchoooo
Thread starter- Joined
- Mar 8, 2008
- 16
merc 454 trs drive, not sure model number as block was changed in the past and there is no number, not too sure about the year either. Carbed, Thunderbolt IV with module on riser. While the engine was winterized i did the manifolds and risers, cap and rotor. Now it won't start and is acting as if the timing is off (popping and hissing back out of the carb). I double checked all the wires and they were correct. I even removed the number one plug to make sure that when the piston was at T.D.C. the rotor was pointing at the correct wire in the cap. I then did that for number 3 and 5 as well and they all were at T.D.C. in the correct locations at the rotor. I checked to make sure the engine was the correct rotation (standard) and it is and the rotor moves the correct way giving it a firing order of 1-8-4-3-6-5-7-2. I was just curious what test i should do next, should i be testing out the sensor in the dist, the module on the riser, or look towards compression testing? I've winterized this plenty of times before with no problems, i'm just hoping that has nothing to do with it. thanks in advance.
