I have a 1991 35hp that has a terminal bar on the side of the engine block. The treminal bar indicates that the tach signal wire is purple. I've heard that this is a standard configuration. I have power to my tach (it lights up and pegs zero when I start the engine), but stays at zero RPM no matter how much the engine revs, and no natter what pole setting I select on the back of the gauge. I should mention that the gauge is brand new.
Should the purple wire on the terminal bar connect to something else on the motor in order to get a signal for the gauge?
If it isn't obvious by now, this is the first motor and boat that I have owned.
Any help that you experienced mariners may have would be greatly appreciated.
ABlank
ABlank
