No tell-tale when using flush adapter.
hcrumbie
:confused: 2001 Johnson 25hp. I can't get water out of the TT when using the 'muffs'. I have tape over the 2 holes above the inlet on both sides per the OM. No problem when it's on the water. Any hints?<br /><br />Flustered flusher, <br />hc
muskrat
Re: No tell-tale when using flush adapter.
remove water screens holding muff off gear case water inlet.buy a dual feed flush muffs.
Walker
More water pressure on your hose.
