No trailer switch?
fasteddie760
Hello all. I recently bought a 1990 Eliminator 234 Edge and replaced the trim sensors to fix a trim gauge problem I was having. After replacing both trim sensors and trying to adjust the trim limit, I noticed this boat does not have a trailer switch. And rotating the trim limit sensor does nothing to the length of the rams.
When I set the trim gauge to read correct in the down position it only shows 3/4 when fully up. What is the ram length when fully rasied on a bravo one drive? Mine is 27" center-to-center.
I attached a picture of the only trim switch in the boat.
that is a tilt and trim switch.
I bet either you push it further up (second detent), or you push down and up
fasteddie760
Thank you for the reply. I'll try that. Because right now it goes fully down and fully up with no second detent. Maybe a bad switch.
Ed
