bayprowler
Thread starter- Joined
- Mar 14, 2011
- 22
I have a 1987 Johnson 140. I just installed a new regulator/rectifier thinking that would cure my tach problem - it didn't. I've determined that I have no voltage on my tachometer circuit as tested at the gray terminal of the terminal strip next to the regulator/recitifier. The manual says to perform this tachometer circuit test if the boat's tachometer is not working (it is not) or if the VRO "no oil" warniing signal is in question (it started failing a couple years ago). The manual does not explain what to do if the tach circuit does not test ok. I'm wondering what do I do next? (btw, the stator checks out ok)
