No water coming out telltales, impellor is OK
waterdog71
Checked impellor and it is fine. Could it be Thermostats. Where are they located in 87 50 HP Evinrude VRO. Any other things to check. Losing valuable fishing time.
alden135
Re: No water coming out telltales, impellor is OK
Did you try running a wire up the tell tale to see if it is blocked? Have you checked the head temps?
waterdog71
I pulled the line off from the telltale and put the air compressor to it. I could fell air coming out the lower unit. Haven't checked head temps.
willamettejeff
Did you check the telltale outlet fitting itself? These themselves can get plugged which is why alden suggested running a wire up it.
waterdog71
I could see sunlight through it
Goodoleboy
Your drive shaft may be spinning inside the water pump impeler. Theirs uh little drive cam flat on one side round on the outside. <br /><br />The sharp end is leading edge and rotates in clockwise direction with drive shaft. If this cam gets out of place the water pump quits turning.
Lasse Lehtonen
Did this problem appear after you changed the waterpump impellor or just suddenly? I dont know much about your motor, but I suggest there is thermostat(s) and a poppet valve.Is it cooling in high rpm? Have you checked there is no weed etc in the water inlet holes? Those thermostats usually control waterflow in lower rpm to keep engine warmer to produce less smoke, but if there is a poppet valve also it should open when water pressure increases (revving the engine)and let more water trough the motor.
waterdog71
Problem occurred before water pump impellor was replaced. Old impellor was looking back so I replaced it but still no water.<br />where is the poppet value located?
Lasse Lehtonen
It may be the poppet valve (sorry I don´t exactly know where it is situated in your motor, but I think the manual knows...)It may also be that the pieces of your old impellor are now in your cooling system blocking the water passages. (check the poppet and thermostats first)I still think the problem is in the thermostats cause they are controlling the waterflow in low speeds, the poppet valve is all way closed normally when trolling at low speeds, but if you rev your engine and there is still no water coming out, the problem may be blocked waterpassages or broken thermostat(s) and a jammed poppet valve.Are you sure there is no exhaust gases or water vapour etc coming out of the "pee-hole", also blown head/exhaust cover gasket can cause this.
surfthis
Is water coming out the exhaust ports? If so, your impeller is working. Not sure, but your thermostat housing should be above #1 cylinder on the head (top, back of powerhead). Should be four bolts holding it in. It's easy to remove and inspect.
eaglelove76
hi did you get it to work i just went through that with my evinrude 100 i had to replace the thermostat you can take the thermostat out and put the cover back on and run water and it should flow through exaust outlet then you will know that its the thermostat<br /><br />roy
