Hi there,
I have a cooling system problem. I am not getting any water flow through my supply pump. I have removed the inlet hose from my pump and there is no trace of water with muffs attached. While the the hose was disconnected I attached a garden hose to check for obstructions and had a good flow of water from lower unit intakes. I then sealed the intakes with tape to check for leaks and could not find any. I also removed the outlet hose from the raw water pump that supplies water to the thermostat housing both with muffs and in the lake- still no water.
I have done some work to the boat in anticipation of the upcoming boating season that I think is relevant:
-Removed outdrive and water tube nut. I did not replace water tube o-ring but instead used old o-ring with a bit of gasket sealing compound
-Replaced thermostat, temp sender and impeller. I did replace impeller o-ring, which I believe I installed properly but when referencing a raw water pump diagram noticed a small washer at the tip of the shaft that I did not replace nor did I see when I had the housing off.
I did a lot more work but I do not think it would be helpful to diagnose this problem. Any help would be much appreciated. I did not yet inspect the impeller again as it is a PITA to remove but I will take a look as soon as I get a chance.
2004 Larson 180sei
3.0GLM-B and SX-M
2004 Larson 180sei
3.0GLM-B and SX-M
