no water flow
sinnie1
Sirs I have a 1983 Johnson mod. J15RCTA.
I have a water flow problem will the water flow from the little pee hole in back
when you first start the engine .or will the theromstat stop the water flow untell the engine is wormed up .I changed the impeller and have had the lower gearcase off and on three times to check every thing could . I have a thermostat problem or what am I over looking ps. on water flow. thank you for any help.
