No WOT Unless Choke Pushed In?
KYVETTE90
First of all I'd like to say that this is an awesome forum, very helpful. I have a 48 hp Evinrude outboard. Took it to the lake, ran fine for about 5 minutes then lost power. The engine will not rev up when throttled unless I push the key in with my knee and hold it there. So the engine will not speed up unless I use my knee to hold the choke in. Spark plugs are new, new fuel. Ran a whole tank of gas with no problem accept having to hold the choke in the whole time. What could the problem be? Thanks.
KYVETTE90
Re: No WOT Unless Choke Pushed In?
Is it possible to take the carbs off, clean them and reinstall without tuning them afterwards? Can they be cleaned without removing the jets or any other parts that have to be readjusted? Do the gaskets usually have to be replaced after carbs have been removed or can they be reused?
glassmaster68
get carb kit,,,,,clean out jets,,fuel and air passages replacement gaskets usually come with carb kits,yes low and high speed needle valves will have to be retuned,,not a hard job
kenmyfam
Agree with the others, clean and service the carb's
5150abf
You have to physically remove the jets and clean them with a copper wire, the rest of the carb can be spotless and if you don't do this it won't work.
KYVETTE90
I took the carbs off, drained the bowls into a clear bottle and found that there was some water in my carbs. I took the carbs apart, cleaned them thoroughly and put them back on. I am going to remove my gas tank and lines and drain them and clean the tank and put it back together. What kind of pipe dope do I need to use on the fuel tank fittings and where can I get it? Thanks again.
