noise
bones774
I have been hearing noise at the rear of my engine, iI thought it was some type of rattling/banging driveline noise. As I got closer to engine bay for inspection I put my hand on the port side exhaust(the large metal pipe after the rubber connectors heading down and out) and felt the noise and vibration kinda coming from that pipe. Could there be something in that piupe thats loose or flapping?
I had the outdrive off this winter and the u-joints looked fine, so i didn't think it was them.
Any ideas,
thnaks
bones774
Re: noise
I'm not familiar with marine engines, yet. I Kinda get the idea but could you elaborate on diagnosis and repair please. Thnaks
Don S
Re: noise
The water shutters (Item 6 in drawing) are a flap of SS in the exhaust designed to prevent (slow down) water sloshing up the exhaust when the engine is no running.
When the shutters wear the rubber off, or the rubber gets burned off in an overheat, and the engine is idleing, you can sometimes hear them quickly opening and closing as they bang against the inside of the pipe.
bones774
Re: noise
Repair or replace? any diagnosis to ascertain for sure?
Thanks
Don S
Re: noise
Follow the noise to locate, take it apart and inspect. If the rubber is gone, replace the shutters.
bones774
Re: noise
Did some additionla research and seems like an older 3 piece manifold requires engine removal for shutter replacement. Does anyone know if a 1988 350 Merc is considered an "older" engine with 3 piece pipe?
Thaks
Turn-n-Burn
Re: noise
from what I gathered.......is this what your exhaust looks like leading from the risers?
attachment.php
if so....just remove the elbow
Don S
Re: noise
I used the serial number you have listed in your signature, so the picture I posted earlier is for your engine.
