Re: Noisy operating noise
For my engine (chev 350) cover I attached 1/2" noise control barrier material from West Marine. For 1/2" X 32" X 54" its about $80. 1" thick material is about another $20, but be sure you have enough clearance for it on all sides. I don't know how well the glue will hold the added weight of the 1" thick material.<br />I had enough left over to put a second layer on the vertical portion of the engine cover facing forward towards the cabin, which is where I thought the extra material would do the most good. Seems to be doing a good job of holding down the engine noise. <br />I attached both layers with 3M spray adhesive, applied to the material and the engine cover. Carefully compare the different 3M adhesives before you buy it. Its been mounted for over 2 years and is holding up well. Good luck with your project.
