Non existant drain plug installation
shovelhead82
I have a 12' Appleby MFG rowboat aluminum that I have restored somewhat and am using with a sears 5hp. Pretty feeble set up but the price was right IE free. I would like to install a drain plug on this beast, any input on doing this the easiest and best way?
I appreciate any input out there
Thanks, Art
reelfishin
Re: Non existant drain plug installation
Personally, I wouldn't drill any holes in a hull that has none to start with but if you must, you have two choices, either have a 1" tube welded in place through the transom to accept a common drain plug, or try to bolt on a garboard style drain with some stainless nuts and bolts and some 5200 sealer.
See these choices: http://www.iboats.com/Boat-Parts-Ac...298223--submit.Search--submit.x.0--submit.y.0
A small bilge pump and battery would be the easier answer though. If storage is your concern, a 12' boat is light enough to just flip upside down.
rwidman
Your problem will be with dissimilar metals and corrosion unless you can find either a non-metalic garboard drain fitting or an aluminum one.
Home Cookin'
for that set up you want the 1" drain and plug inside, so that you can pull the plug while running and drain the boat.
Since you do not have a 12 volt battery (unless you also use a trollnig motor) a conventional bilge pump is not what you want.
First choice, you could get a hand pump--cheap and efficient. You can even mount it to the transom.
Second choice, get a pump that runs on D cell batteries; it's all you need. My mother used to use one on her 14' rowboat, rather than bailing after a rain. I took it and rigged a float switch to it.
If you are using a trolling motor and don't want manual, rig up alligator clips to a small bilge pump.
shovelhead82
Sorry for multiple posts, I'm new and as far as I could tell they weren't posting...oops!
I see the point of not molesting the transom with a hole, a small bilge or hand pump might just be the answer. The boat is not worth much as it was damaged and I used marine tex to seal damage. it's holding up very well.
Pez Vela
Over engineering a simple desire to drain and/or dry your boat is probably not a good idea. Here's Sponge Bob to the rescue!
robert graham
I've had an aluminum canoe for years and often thought of adding a transom drain. If I ever do it, I'll most likely have a 1" aluminum pipe welded in my transom with a 1" plug. My large aluminum jon boat has that for a drain, only it's a 2" diameter pipe/plug. You WILL remember to put that 2" plug in at launch or it WILL sink in a hurry! Good Luck!
Outsider
Jeez, it's a 12' boat, cut a quart milk jug into a scoop! It don't get any cheaper than that, nor would it get much better ... :eek:
rwidman
And it could also be used for an MSD. :rolleyes:
