Re: Non skid replacing carpet and more ? ?
......You'll want to look for a good way to reinforce your deck under the pedestal seat.. it puts a lot of force on the deck. Also be aware that you're not supposed to use a lot of those pedestals above a certain speed.
Erik
The problem with a lot of seat pedestals is that they don't have a base or top section that can take the pounding at higher speeds, especially with a larger passenger. I've had several collapse over the years. I weigh in at 275lbs, and none of my boats do much more than about 45mph, and I've had just about all the major brand pedestals fail in some way or another. I've even had two or three Pompano upper swivel sections punch through at the top on rough water. The problem is that they use plain cast aluminum, and its not often very heavy duty. The upright is rarely a problem, and I've only had one snap at the base. The first one that failed was a fully adjustable swivel top on a fairly expensive seat and pedestal, it gave way in rough water landing me on the floor backwards. The fall wasn't that bad, but the worst part was getting back through the breakers without a seat while trying not to get impaled on the remaining post as I drove kneeling and leaning on the gunwale and trying to stay in position to maintain control of the boat and both engines.
I ended up building a wooden box and mounting a fixed seat right too it. I wasn't going through that again. It wasn't a speed boat and I wasn't going fast, the inlet was just rough and the boat was getting tossed about a bit.
The worst pedestals are the narrow steel 'Bass boat' type, they put the most strain on the deck and have very little support in rough seas.
