Non working trailer lights
DaveyHAZZ
Got this boat and trailer last month.. Lights didnt work. No biggy. Just wondering the possibilitys.. Bulbs are in great condition. Any way to test if wires are good?
tractoman
Re: Non working trailer lights
About 95% of trailer light problems are bad grounds. I always use a battery at the coupler to test the wiring on the trailer and connect the negative battery lug to the trailer chassis. See what's working. You can test the wiring with a meter for continuity, and use the meter to check for 12 volts at the sockets. Don't rely on a ground to transfer through the hitch to the trailer. It should be in the pigtail connector.
DaveyHAZZ
All fixed. Was just alot of loose wires.
