Noob Considering purchase of "Blue Flush Cap Overheated" 2003 Glastron Volvo 5.0 GL
Hello All,
Have always wanted to have a boat - finally have the means to consider getting one.
There's a local listing of a 2003 runabout with a 5.0L GL motor that has been overheated. Apparently, the current owner's son had done a flush prior to heading out for the day and forgot to close the blue flush cap. He ran it. It overheated. Poked around the engine compartment "meh, maybe it'll work better this time" and it overheated again. Definitely not the cautious patience of some other fellow posters I've come across in the forums. The boat has sat idle for 2 years since that ill-fated day.
My inclination is that it's at least worth a look; the owner is in a financial pinch and this could, potentially, be a way to a nice first boat that wouldn't break the bank.
Here's where you guys come in: Are there some non-destructive/immediate clues I can be on the look out for when I see the boat that will indicate whether this package is a lost cause, a 50/50, or a "probably OK with X,Y, and Z"? I can't expect that it would be a good idea to try and turn over an engine that's sat idle, most likely without the "winterizing" TLC, for two years. I'll save the "start-up" checklist request for a later post should things progress.
Any sage advice would be greatly appreciated.
Thanks,
Joe Marin
Hello All,
Thanks,
Joe Marin
