Just joined up, looks like a real good site. This is probably old hat to some of you. My 90 HP Force got so it wouldn't crank. Starter would turn up to co mpression and then stall w/ batt reading 12.3 v. Checked ALL CONNECTIONS, finally removed starter and disassembled it. Found bushings were dry. Greased them up, reassembled and reinstalled starter and it spins like it oughta now. Thought I'd pass this along to maybe save someone buying a new batt that isn't needed.
I also have a question about the choke/primer. Does it only work when the engine is cranking or any time the switch is on and pushed in? I can't hear the solenoid clicking when it isn't cranking
Mike
Mike
