acdc96
Thread starter- Joined
- Apr 23, 2013
- 412
Well when I was letting my engine run and doing some performance checks, I noticed that the block was really warm so I looked at the temp gauge and it said somewhere around 160 degrees and it I checked back after a little bit and it climbed to 180 degrees so I shut the engine off and waited a half hour for it to cool off and I drain all the hoses and block and manifold. It was a little rust colored but no big chunks. I took the riser off and flushed those and their where a lot of chunks in their. So I flushed the manifold as well. Painted the risers with rustoleum engine paint and put it back on with new gaskets. I pored 6 gallons of water mixed with a little vinegar (1 pint for the 6 gallons) drained the block after a half hour and flushed it again with plain water.
I hooked up everything and started the motor and let it run at idle for 30 min and it shot back up to 165 degrees.
When I had the boat in the water 8 years ago the normal temp was between 140 and 170 degrees at cruising speed. (Around 30 mph).
So is this normal temp for my engine?
I just replaced the water pump in the drive and it pumps water just fine. Newer thermostat. New riser gaskets. Clean water pump with new gaskets on engine.
1986 mercruiser 260hp V8
