Normal Oil Pressure Range
LegacyT
Hi all just wondering what the normal oil pressure range is cold/hot and idle/cruise on my style engine... Mine shows about 70-75 in cruise and 45 idle and hot.
Re: Normal Oil Pressure Range
Ayuh,.... 10 psi, per 1000 rpms is considered acceptable...
Don S
Put a mechanical gauge on it and see what you get. That seems a bit on the high side for an old engine.\
Here is from the manual.
min. 2.1 kp/cm3 (30 psi),
nom 4.2–4.5 kp/cm2 (60–65 psi),
max 5.6 kp/cm2 (80 psi)
