starcraft67
Thread starter- Joined
- Nov 20, 2007
- 21
Hello y'all. New poster here. I've enjoyed reading your posts and learned a lot. I have quite a bit of experience with a Johnson 9.9 (1998) with remote control so know my way around a little outboard anyway. I just bought (for practically nothing) a 1967 Starcraft 15 ft. closed bow aluminum runabout with the original '67 40 horse Evinrude Big Twin (and the original trailer with the original bearings and spindles but that is another sad tale). It has the dual control lever setup. It is said the motor runs well, and I heard it cranked over and it sounded swell. My question is: what is the ordinary starting procedure for this setup? Over here you've got the two levers, and on the dashboard the ignition key. On the front of the control box is a little twist knob that says idle adjust or idle stop or something similar. On the body of the carb is a little lever to choke manually if need be.
So, after hooking up a good battery and priming with the fuel bulb, what's next? My guess was, after doing some reading -- shifter in neutral, throttle a little bit forward, turn key, pray. I'm used to the 9.9 Johnson's push-key-in-to choke and pull up fast idle lever, but I'm not quite sure what to do with this old Big Twin so I'm not just sitting there wearing down the battery because I don't know the starting procedure. Also, what is the normal position of the choke lever on the carb body?
I do appreciate the help of all you learned gentlemen and ladies.
Starcraft67 aka Joe
Marietta Ohio
Starcraft67 aka Joe
Marietta Ohio
