Normal Temp 1997 Mercruiser 5.7 Bravo 3, 250 HP
Mr. Impulsive
Hi,
Brand new to this forum but am a member of a Corvette forum like this which is invaluable. I just purchased a 97 SeaRay 250 Sundancer with a carburated Merc 5.7 Bravo 3 I/O. Can anyone let me know the normal temp that this should be running. When I took it out for the first time it ran above 170 ( about 185)and didn't come down. This was my brother's boat, meticulously taken care of. He had a new thermostat and body impeller installed before shipping it to me. I do not have the engine operators manual with the normal temp referenced in the regular owners manual. I have the merc sterndrive paperwork but it deals more with engine installation and start up rather than specs. I am going down to the boat today with an IR gun to test the temp at the thermostat gooseneck but need to know what is normal. I felt the thermostat housing the day I took it out and it felt cooler than 170 which makes me think it is the guage or sender. Any help to a newbie would be appreciated.
Don
Re: Normal Temp 1997 Mercruiser 5.7 Bravo 3, 250 HP
Ayuh,... Generally speaking,... Boat motor T-Stats are 140? or 160? or with closed cooling, 180?...
So,...
With the info you provided,... It could be any of the 3....
Mr. Impulsive
Thanks for the help. I'll check it with the IR gun when I go down and take it from there.
TilliamWe
Banned
It's a little red apples to green apples, but my 1997 5.7EFI Mercruier had a 160 degree thermostat in it, and it would show about 170 on the gauge.
Mr. Impulsive
TilliamWe,
Thanks for the input.
Don
AZSenza
My 1997 22 foot Larson with the same 5.7 250hp Merc shows trhe same thing. It warms up to 170-175 and thats where it stays, all day all night, when we idle down for say 10-15 min it falls off to about 160 but will go back to 170 after a few minutes (I'm assuming thats the therm going from open to partially closed to go back to 170) My boat was also very well maintained by PO and myself. I think its normal. Im reluctant to open it up to check the therm temp.
TilliamWe
Banned
TilliamWe,
Don
You are welcome. And I just looked at the few pages of my Mercruiser Operation and Maintenance Manual, that I copied before I sold my boat, and all the V6 and V8 engines in 1997 had 160 degree thermostats.
Mr. Impulsive
Checked it with an IR gun and it reads about 160 so it's probably a sending unit issue. I have the same issue with my 65 Vette. Thanks to all for the help. It looks like I'll be a regular on this forum.
TilliamWe
Banned
Glad we could help. Glad you confirmed it with a technical tool, and welcome aboard!
