Not a bad day
jayhanig
Master Chief Petty Officer
I bought my '85 Galaxy at the end of last August and found out that the transom was rotted on my very first trip into the sound... I was lucky to get it back out before it sank. I was warned at the time that I was stepping into a hole with apparently no bottom; that it would be smarter to just walk away and part out the boat. Well, I didn't want to do it. Call me stubborn; call me stupid, certainly call me well warned.
So I opened my checkbook and started fixing the problems as they became apparent to me: the transom was replaced, the outdrive tilt was repaired and another switch was added to the transom for access in the driveway. I had the boat professionally rewired and my panel replaced. The steering rack was replaced as it froze itself solid sometime between when I got the boat and March. The fast (3000 rpm) idle was corrected with a new throttle cable (the old one was completely makeshift rigged). I added Smart Tabs, a GPS/ chartplotter/ depth finder, and a VHF radio. I rewired the trailer and replaced the wheel bearings, rims and tires.
I named her the "No Good Deed" as in "no good deed goes unpunished" - one of my father's favorite sayings.
Today I got brave and towed it down to the municipal marina and launched her with the help of an old high school buddy. No doubt it could have been done a little better than I did but I didn't forget to put the plug in; I didn't forget to release the transom straps; I didn't forget to lower the outdrive on the way in or raise it when I came out later.
I didn't embarrass myself backing the trailer, which is an improvement over last year. I didn't hog the ramp and I was in and out pretty quickly.
So what happened? I followed some other boats and got a sense of where the sand bars are around the marina and on down towards the New Topsail Inlet. I stumbled a couple of times into shallow water but never got stuck. There was no water in the oil when I got back. Pulling the plug gave me maybe 30 seconds worth of water at the end of maybe an hour and a half of tooling around. The Smart Tabs worked great! I went on plane very quickly and there was no wandering at slow speed, unlike last year's singular effort.
So not bad. The one negative is there is still a problem shifting from forward to neutral to reverse that made for exasperating times when I was trying to dock. But I didn't crash into anything. I'm going to let my boat guys take another crack at the shifter and see if we can't get that squared away. But after a whole lot of trembling, twitching and whining, I think I have a usable boat!
I am a crispy critter this evening. I suspect rum and tonic will correct any discomfort shortly. ;)
Ciera2450
Re: Not a bad day
Sounds like you had a good time!
Rum and tonic always helps with a sunburn, btw.
NYBo
Re: Not a bad day
emoney
Re: Not a bad day
That sounds like a GREAT day. The paranoia, however, won't subside anytime soon, I assure you of that. Heck, even my wife is at the point of telling me to quit worrying, lol. Nothing, I mean nothing (outside of a couple things like kids being born, wedding (she's looking), etc.) beats a day on the water in your own boat. Even with all the stressing, it's still the most relaxing thing in the world. I will add, however, that sun screen is sold almost every store you go and probably should be on your next shopping list. Congrats on the day, now get back out there tomorrow and repeat it!!!!
Jeep Man
Re: Not a bad day
Congrats on a successful outing Jay. May you have many, many more.
soggy_feet
Re: Not a bad day
without even looking at Fed's link, Im gonna guess Shift Interrupt Switch, and/or leaking shift link cable bellows, which may also explain the water in your hull.
Otherwise, sounds like a pretty good day on the water. Hopefully, plenty more to come.
JoLin
Re: Not a bad day
Well done, Jay! Sounds like you're really getting there, and I think that's just great.
(I'll probably post my own 'first weekend on the new boat report' tonight or tomorrow :) )
tonk62
Re: Not a bad day
Sounds like a great day. I once had a 22 foot galaxy, i restored, OMC 5.7 with cobra outdrive. Had the same problem when docking, it got so bad i would have to kill motor coming in, shift to neutral then restart motor and shift to reverse, had to be quick and pray it started!! 90.00 at the local marine shop for a new shift interuper switch fixed everything.
NHGuy
Re: Not a bad day
Good for you, you're doing great. Isn't it just great to tool around out there?
And I agree there should be no water in the boat. That's worth solving.
You might end up doing a drive bellows and the lower shift cable. Might only need the leak found and a shift adjustment. Although doing over your transom probably included the bellows.
Whatever, it's worth fixing and you are almost 100%.
