artificialreef
Thread starter- Joined
- Feb 21, 2009
- 504
Hi folks, just thought i would share this with you. I was incredulous. I am in the process of trying to resurect a boat that has been sitting for 2+ years. Needless to say every other bolt i tried taking off strips out. (i am using pb blaster but..)Drilled out 2 so far, but i get to jacking with the broken trim pump. Its a R drive w/a Oildyne metal resevoir. The plastic manual release falls apart in my fingers. I remove the pump to put it on a bench to put a replacement in. Drilled a small hole into the center of the PLASTIC screw and lightly tapped a ace hw bought easy out in. Proceded to break a hardened steel easy out in a plastic control valve.
Old boats s***.
replacement part nla. did find one though.
Old boats s***.
