MagothyMike
Thread starter- Joined
- Jul 2, 2009
- 7
The washer end of the torque hub has "coned" out. Last season the boat (1999 Trophy 2352 Mercruiser Alpha 1 5.0) lost speed. I pulled the hub and found the hub coned out on the back section. The locking side was still intact. I replaced the hub assembly and tested the boat. Speeds returned and I hoped all was well. This season after a few fishing trips I accelerated but couldn't get the boat to go over 4100 rpm (in idle engine will red line) at 21.5 mph (GPS). I pulled the boat and inspected the hub. Once again the rear section of the hub displayed signs that it was again on its way to coning out. I can't find any play in the shaft and the thrust washer looks fine. The prop is a three blade aluminum 15 inch with 17 pitch. except for being under water it shows no obvious signs of damage or distortion. It seems to me that in order to create this fault, either the prop or the shaft are wobbling during load, and this wobble creates the coning out of the rear section of the hub. Sort of like exaggerating a drill bit around and around to hog out the initial diameter. Any ideas expressed would be terrific!
BTW, the boat has not over heated or displayed any other running troubles. Temp is steady ay 175.
