Not Getting Any Electrical Power to Mercury 150 Saltwater
DRA2256
I have a 22 foot 2000 Bayliner Trophy (Model 2052 FD) with a Mercury 150 XL Saltwater engine (serial OT143592). The boat was running great until I stopped to get gas. When I started to cast off, I turned the key and got nothing from the engine - not even a turn over. I tried the remote power trim and it did not move. I tried the button on the side of the motor and it would not move. It sounds like there is a breaker between the battery and the engine is tripped but I can't find it. Can anyone tell me what is wrong or point me to a good electrical system diagram I can use?
carholme
Re: Not Getting Any Electrical Power to Mercury 150 Saltwater
Your s/n comes up as:
MERCURY - (150 H.P. (2000 ))
Serial No: 0T143592 Model No: 1150462WD
Parts and Service Bulletin List for s/n 0T143592:
Search Results - Crowley Marine
You should have a 20 amp fuse which you can find if you follow the red/purple wire back from the cowl mounted trim switch. Also one of the small red wires from the trim up solenoid should take you back to the fuse.
Gerry
DRA2256
Gerry
Thanks! I traced it to a bad connection in the fuse connector. The fuse was good but not always making a connection. I appreciate your help.
