enginesilo
Thread starter- Joined
- Jun 9, 2008
- 355
Curious what some possible things to check are with my motor not getting up to Max RPM's suddenly?
Boat ran fine the first handful of times out but the last 2 times it would only get up to about 3700-3800rpm's and felt sluggish. It usually runs in the 4400 RPM range. I have ther Mercruiser 3.0L engine.
I was planning on checking:
-Spark plug gap and wires
-Change spark plugs if they look like they need it
-Check fuel pump filter-Does the 3.0L have a fuel filter inside the fuel pump? (The small one that is attached to the engine, I do not have a separate fuel separator installed)
-I know the carb could be to blame, but I want to try to rule out other things first
I also heard another boat had water in the fuel from filling up at a marina where I also filled up a few days before. Now that I think of it I started seeing these symptoms after filling up.
Would water in the fuel cause it to run sluggish and not hit max rpm's? Seems to run fine at lower rpm's though.
I think I might siphon some gas from the very bottom of the tank to rule out if I had water pumped in with the fuel.
Any other tips appreciated
