I have a new to me rebuilt 1985 Johnson 115 that is not getting water to the heads, but it is pumping a good stream of water out of the tell tale. I bought this motor from a shop that went under and it had taken a fall and cracked the lower cowling. I recently located a compatible lower cowl and switched the two. I cranked it up and after a few minor issues like hooking up the enrichener lines and correcting the coil wires got it running well, but it quickly overheated on the muffs setting off the alarm.
I have verified that the diverter tubes are in place and not blocking the flow, the head gaskets are on correctly. I pulled the water jacket covers off the heads and they are clear as are the heads and water passages around the cylinders. The tell tail is located at the botttom of the bubble back exhaust and water will start flowing to it with in a few revolutions of the motor even when it is not running. The thermastats are new as it the impeller.
All of this is being done on muffs. I read an old post where someone said that they could not get their motor to cool properly on muffs but it had to be submerged and then it ran fine. Has anyone else run into this issue. The water comming out of the tell tale indicates to me that it is hooked up correctly. I really don't want to go it down to the boat ramp and block it up trying to see if it will run without overheating if I am missing something.
I appreciate any ideas that anyone may have. I have ordered new water passage gaskets so I will be down a few days anyway. Otherwise I guess I will have to try to put the boat in and see if it will run correctly. I have had other 115's and they all ran fine on muffs.
