oregonboatnewb
- Joined
- Dec 6, 2008
- 283
So today i finally had time to investigate the batter/drain plug on my new boat...
Boat had been sitting garaged for a year, i put in plug, test drove it last week on water, got home, pulled the plug and red water came out.
Today i removed the oil reservoir, so i could see what was going on...
There was alittle visible water in the area behind batter/oil holder... and the boat was already on tilt backward alittle... so i jacked it up with a car jack, and more water showed up in the area rear of the boat...
The water was red, and even a spare water bottle was lodged up in it... I Used paper towels to test the floor once i removed all the water i could with paper towels (the thing was tilted alot backward, but still i can see theres alittle water in the middle area, i just can't get to it or the motor would touch the ground). Once dry, i poked all around the floor with a screw driver, solid as a rock... the plug whole how ever, was soft... i would have imaged that there should have a plastic piece of pipe or something, to let water out w/out touching the transom wood, but it seems that there's nothing but a touch of silicone on the sides of the walls...
The bottom of the plug area was soft, i could poke around with a screw driver, and remove alittle material, and once i did, the area underneith the 1/8in of wood i removed, was rock solid...
This boat has 220 hrs total on it, garaged its entire life... The boat when back into the water, had straps still on lol and got alittle water i'm sure up and over, but i can't imagine this just happening few weeks ago, would have given it time to rot that area... also when i picked up the boat, and drove it home, no water came out of the lower part. I also checked back there before i purchased it, and didn't see any water...
Does the area that surrounds the plug have any sort of tray of materials that would get soft, but not affect other area's of the floors/transom ? OR does water that goes out that whole, have access to rot through out ? The transom is rock solid, the place i had it checked out knocked all over, and looked for signs of stress, but everything checked out... what should i think of this ?
before i tilted it back even more, and paper toweled it
after i paper toweled the water up.
plug area that is soft on the inside middle bottom...
