Not sure what size hoses to get??
ifishhard
CAn somebody tell me what size hoses are on a factory 1996 75hp force? I am wanting to replce my fuel hoses with new ones and I am not sure of the correct size? I want to replace all of the check valve hoses around the fuel pump and the ones that are connected to the carburator. THanks
maxum247
Re: Not sure what size hoses to get??
Best to take a sample of each size hose to the auto or marine store with you when you go! Don't forget to figure how many inches or feet of each size you need to buy. max!
GrindKore
I used 3/8 12' universal fuel line assembly from West Marine on my FORCE 90. The hose diameter is larger than OEM, but not by much. I have used house clamp to secure it to the fuel pump. It was difficult to get it through the engine grommet, but I used some silica grease and pulled it through just fine.
john from md
Most of the newer motors use 3/8 inch hose but then again, this is a Force and it may be 5/16 still. Best measure it to be sure.
John
