Not sure what to look for, water flow.
thx997303
I have a 67' 9.5 horsepower Johnson, and when running in my water container, it sprays water out of the back, underneath the engine.
Thing is, it sprays, it's not a stream.
Seems like so long as water is above the anti cavitation plate, it sprays. But if it's below it, it doesn't.
Sprays the same at all RPMs.
This is a picture of the grommet from which the water sprays.
Good? Bad? Ugly?
71Windsor
Re: Not sure what to look for, water flow.
thats a pretty good water flow to me. and you will absolutely need to have the water line above the cav plate.
thx997303
Is the water line in that pic about where I will need to set it?
ezeke
That or higher. The water pump is just under the bottom of the midsection and needs to be submerged when running in a bucket.
When you are running on the water the propeller pushes the water into the water intake so it is not so important then.
thx997303
Good to know.
Sorry, I'm new at this.
