Not sure what to use for the Stringers?
gofast63
Re: Not sure what to use for the Stringers?
JNG makes a good point. Since I usually use a cradle and do level the hull the method described works for me. However since this is not always the case, GWPSR's method of vertical measurements is a good one to. Marking the deck level on the sides of the hull and Laying a board across the sides of the hull at various locations and then measuring to the bottom of the hull will give you the stringer dimensions as well. There are many ways to acheive the same results. Whatever works best for you. It's not Brain Surgery and you'll come up with a method that works best for you I'm sure.;)
Yeah, thanks. I went and bought a laser level early this morning. I'll see how it works.
Thanks,
Gary
