just plain ole Bill
Thread starter- Joined
- Aug 7, 2007
- 55
Yeehaw! Got my shop manual today. Replaced fuel line from pump to carb (it was wet with fuel around the end at carb) and main fuel line to filter (it was cracked at the filter end). Gonna run it on 50:1 instead of 40:1 tomorrow. What can I say about the mix? One of those stupid human things. However..now that I have the shop manual.....
I'm sure it needs decarbed pretty bad since it set up for 3 years and was probably not ever done by previous owner. That will be next along with checking the fuel pump output.
Already pulled and cleaned carbs. They were amazingly clean. Plugs didn't look too bad. Thinking I'll wait till I decarb before putting new plugs in. Throttle cable and associated assemblies seem to be functioning corectly. (Haven't verified finer details of choke yet other than does it choke to start and open up when not required to start? Yes.)
Any other simple things I might consider before working back up to the carbs?
The motor is a 1972 65hp Evinrude.
No need to jump in and do everything at once. Enjoying tinkering and testing. My definition of testing is "Let's go fishing and see how it runs now".
Trouble shooting up to this point has been: Does it start? Yes. Does it float? Yes. Does it move forward? Yes. Take it fishing? YES! Can we get back home with it? Don't know, not done fishing yet. Will the motor shut down if you use all the fuel out of the tank? Yes. (This is where I'd insert the 'redface' icon if I knew how.)
