waterone1@aol.com
- Joined
- Oct 10, 2004
- 1,235
Re: not using marine starter.. should I replace?
Aggiedave, your question has been answered more than once. I just can't believe the fertilizer I'm hearing on here. Trogg, what is your boat....an outboard with a portable six gallon tank ? Every major manufacturer of larger boats has 100-200 gallon tanks that the bottom is not accessible unless you remove the engines to get the tanks out. Are you really saying that people should pull both of their big block inboards every year for an inspection of the full tank ??<br />Someone asks a valid safety question about a starter and you turn it into a dissertation about how fuel tanks shouldn't leak ??? My furnace and water heater here at home should not produce carbon monoxide, but I have two co detectors just in-case they do.....so my family doesn't die ! It only takes one malfunction, either in your boat or at home, and you don't get a second chance.
