hole-in-da-water
Thread starter- Joined
- Apr 30, 2007
- 46
Brought this over from the other forum, sorry!
Alright folks, you can start to berate me or tell me all that I did wrong, but I pretty much know. To start, I have an '86 OMC Stringer 3.0. As some of you may recall, I haven't been able to get it to start. In my infinite novice wisdom, I replaced the fuel pump, rebuilt the carb, and changed the fuel. Nothing, still the same problem. Engine will crank, you can hear it fire, but it will die. I pulled a spark plug and checked for spark, they are getting spark (how thick/bright should it be?) I cleaned all electrical connections, checked all fuses, nothing, same problem. Now I don't have a good guess as to where the issue might be. Can it be the starter solenoid? I was also thinking maybe the assist solenoid, since it will fire but not stay running. Please help! I have to get it running, I have stuff planned for next weekend! (Needless to say, I won't be going out on the water Memorial Day weekend?
