Have a 74' 150HP Mercury inline 6 w/ three carbs outboard I have been working on to sale. I have replaced impeller, rebuild carbs, replaced fuel lines, changed spark plugs and have a compression of 125+/- and has ran quit well until couple days ago when mix fresh gas/oil (1 pint to 6 gallon) I mix 2 gallon gas to about 6 oz and added less than teaspon Murphy's oil (grandfather used this for years with no problems).
Since mixed fuel you can crank, spray starting fluid, choke and does not turn over in start postion until key turns to run/on. At that time wont go for more than couple seconds. Removed the plugs and have what appears to be water droplets and milky residue. Compression still read same. Any ideas other than trying new fuel? thanks
