NS18C2 cuts out at full throttle
tcb1792
I have a NS18C2 and I can not run it wide open or it cuts out half throttle is perfect and runs good anymore and it's crap. I have put new plugs, sonic cleaned the carb, and new fuel lines/filter. Anyone have any suggestions?
MattFL
Did you pass air and carburetor cleaner through every hole in the carburetor, and visually make sure the main jet is clear? The ultrasonic cleaner can be a fantastic help, but it doesn't always get everything.
tcb1792
Yes, after I pulled it from the sonic cleaner I did blow out all passages.
MattFL
Double check the main jet and the emulsion tube if it has one (tube with a bunch of small holes in it). The symptom sounds like it's possibly not getting enough fuel with the throttle open, so I would check everything related to the main jet. Also check the float level and make sure the fuel flow is enough (fuel pump working and filter not clogged).
tcb1792
Definitely plan on checking all this! Thank you for the advice, I'll come back and post the results!
