pvanv
- Joined
- Apr 20, 2008
- 6,570
Re: NS5B Gasket kit sourcing.
One does not bury the heads of the 2 6mm screws. One uses them as puller legs. In this case, they are actually "pushers". They need to be long. You would need to understand how a puller operates. In this case, instead of applying pressure to push in the center, you would be pulling on the prop shaft, and pushing on the bolts, so the prop shaft housing slines off along the bolts.
Try tapping GENTLY as Elvin suggested first.
This is all a matter of having basic mechanics knowledge. If it seems daunting, get thee to a dealer for assistance.
Thank you sir! The engine LU is much better looking than I thought it was going to be. Still have not got the prop housing off, but I have to wait until Sunday as I am heading out of town. The manual does not say much about getting these parts off... It literally says: remove 2 bolts... remove prop shaft housing... and so on. Pretty vague.
Just to be clear, your are talking about putting 2 screws with a crossbar into the 2 screw slots in the LU that screw horizontally into the housing yes? It was my impression that this end part of the housing comes off also, does it not (the very end where the screw heads sit) atleast in my manual it appears that way.
