Nylon Trim Hose has a hole. Replacements?
Friscoboater
I am so close to getting my project on the water, but no one has the little nylon trim hose that goes from the reverse lockout to the bottom of the trim pump. OI was bleeding the system and noticed a leak. I am drawing a blank. Is there anyplace I should look that I could buy it in bulk?
81 Merc 260
Trim pump with the steel tank, not plastic. It has one braided line that goes through the transom and one nylon that goes to the reverse.
Re: Nylon Trim Hose has a hole. Replacements?
Ayuh,.. It's nothing but a low pressure return,...
Nylon air hose used on tractor trailer air plumbing will work...
Friscoboater
Thanks for the response guys.
Don, I am really trying to find something local. I got some of the hose from lowes, but I think the walls are too small.
