O ring help
kulle
Does anyone know where these 3 orange o rings go? they came with transom repair kit. i have the one for the water passage installed, but not sure where these go. they seem too big or too small for the yoke. thanks
kulle
[No message]
Bt Doctur
the 2 smaller ones go on the inputshaft under the gimbal bearing , the larger one goes on the input shaft if it has a groove for the o ring
kulle
the larger one on "input" shaft, you mean the first groove on the yoke ?
kulle
Yes, first groove if your shaft has it ,
yup, perfect got it thanks! well i got my outdrive back on! i did need to use the size 12 merc -kicker tool, but i completed my first ever -water shutter, ujoint , exhaust bellows and trim postion/sender install! need to fill with drive oil and pray she starts and the fwd/reverse work!
JASinIL2006
Small O rings go where the red circle is; large one goes in the location shown by the square.
Bt Doctur
Did the drive come off easily?
Was the gimbal bearing replaced?
Did you check engine /coupler alignment?
If you answer No , something is still wrong because the drive should just push all the way on if everything is correct
kulle
2nd time is the charm..had to take it back off! damn drive shaft, turned and wasnt seated in the shoe on bell housing! learning curve!
kulle
yeah i replaced bearing and used the alignment bar. it went on good, just needed a little nudge, like 1/8 inch. im gonna muff test it this week.
