Greg O.
- Joined
- Jan 9, 2011
- 125
I just re sealed my QD18 and installed lower unit, then while looking for proper shift linkage adjustment I discovered there is to be an O ring on top of the drive shaft. When I removed the lower unit, there was no O ring. My question is, what good does the O ring do, I see no way to hold it in place on the shaft. I did find a chewed up O ring on the floor, and I am betting that is the ring in question. The only thing I can see it might do is to keep water out of the upper splines, but without something to hold it fast on the shaft, it does not seem very effective.
