O ring on top of drive shaft. QD18
Greg O.
I just re sealed my QD18 and installed lower unit, then while looking for proper shift linkage adjustment I discovered there is to be an O ring on top of the drive shaft. When I removed the lower unit, there was no O ring. My question is, what good does the O ring do, I see no way to hold it in place on the shaft. I did find a chewed up O ring on the floor, and I am betting that is the ring in question. The only thing I can see it might do is to keep water out of the upper splines, but without something to hold it fast on the shaft, it does not seem very effective.
nwcove
Re: O ring on top of drive shaft. QD18
you sure theres not a shallow groove in the ds, at the bottom of the splines?
HighTrim
Yup definitely a groove to hold the o ring in. Very important. Water will "climb" the drive shaft as it is revolving, and get into your powerhead. Drop it back down and get it in there, with a thin coat of grease on the splines as well. Not the top of the driveshaft though.
Greg O.
Yea, I just answered my own question by removing the lower unit. There is a groove in the shaft. Glad I happened to stumble onto the the paragraph in the Johnson manual advisng to be sure to install the o ring on the drive shaft. Thanks Chris and mwcove.
nwcove
do a search here on stuck drive shafts.....many horror stories , mostly all related to that little crucial o-ring !
Greg O.
I have seen some of those threads RE: stuck drive shafts. I pulled the L U and will get an O ring. I missed it on the parst break down when ordering parts, and it had desintigrated and fell on the floor when I dis-assembled the motor.
HighTrim
Was it not in your seal kit?
kfa4303
Banned
+1, there should've been a new one in a re-seal it :/ It's just a small, black o-ring nothing fancy.
